weak spark at coil
Is it still the original Lucas OPUS system ? The amplifier on these early V12 ignitions tended to fail due to heat. An autoelectrician I once knew who worked at Lucas, told me all the technicians called it "OPLUS". As I recall, the amplifier had to be moved to the front of the car away from the heat.
All about Lucas OPUS here: -
V12 IGNITION SYSTEMS / AJ6 Engineering
and here, (and how to check it)
Reopus Ignition | The Lucas OPUS Ignition amplifier
holybananas
02-03-2016 09:22 AM
