E type ( XK-E ) 1961 - 1975
XKE brakes
Old 07-02-2010 | 06:34 AM
Fraser Mitchell's Avatar
All the parts you need to rebuild the E-Type (XKE) brake system are available, (at least here in the UK). Most UK suppliers trade on the internet and will send parts to the US; there will also be US-based suppliers as the car is such a popular classic.
I would also suggest you replace all steel brake pipes with cupro-nickel, (called Kunifer) and brass fittings so corrosion is prevented. These are available already made up correctly. All threads on the system will be Imperial, not Metric so take care when purchasing.
Old 07-28-2015 | 03:42 PM
felinecat's Avatar
Being as 69s are series 2 cars with the best type of xke brakes and your car has sat for so many years the master cylinder, vacuum tank, activation cylinder, bellows booster, and all that other stuff, ( resevoirs, lines and the fittings) could all be upgraded to a simple more efficient system.........see e-type brake activation.............
Rivguy
12-04-2020 08:55 AM
xjrjag
09-24-2015 11:08 PM
wannajag
09-22-2015 09:29 PM
SCMike
09-22-2015 08:34 PM
etypo
E type ( XK-E )
09-22-2015 11:33 AM
Quick Reply: XKE brakes
