XKE series 2 1969 Tachometer issue
Terry,
If you decide to open up the tach and look for the problem inside, he are some comments from others forum members of problems areas:Quote
1. As the meter movements wear, lose their lubrication or get dirty, they require more energy to deflect the meter. Try sewing machine oil to improve the meter movement.
2. Check for cracked solder joints
3. A common failure mode is failure of the main timing capacitor C2. Failure of this cap. has caused tachs to be erratic, temperature sensitive or just plain dead. If you suspect your tach to have this problem, locate the capacitor, carefully un-solder the capacitor, and replace it with a new one. I have been occasionally able to locate a supply of 0.25uF capacitors, but available 0.22uF to 0.27uF capacitors work fine.
4. Some tachs have a failed input transistor. The germanium transistors used in the Smiths design have a very low threshold voltage. Silicon transistors have a much higher threshold voltage. It is likely that replacing the germanium transistors with silicon transistors could really change the characteristics of the tach. However, I would stick with the germanium transistors. The HEP 253 number is still a good number for finding a germanium replacement, although they are hard to find. You sure can't get them from Radio Shack anymore. There are some small electronics distributors who still do carry them. Another good part number is NTE158. Quote
Other forum members may have a favorite repair shop for Smiths Tachs, if you just want to send it out.
Rgds
David
Rgds
David
Tach issue
I changed the capacitor and the gauge works much better, in fact it is scary steady.
i have the transistor on order from the US, I cold not find a Geranium (spelling) transistor in local electronic distributors.
thanks for the advice.
now the car is leaking oil, seems one thing after another.
David84XJ6 (08-05-2020)
