clear coat peeling 88 xj6
I have the same issue.
The worst places were the Hood and roof.
I had a half arsed go at the trunk but it looks pretty bad right now.
The hood I took a fine sand block to, then a very fine wet/dry to remove any lumps and bumps. Then applied 1 layer of rubbing compound and 1 layer of hard wax... It came out soooo much better!. A few more layers of wax and it will be fine.
A better solution would be to remove the clear coat and take it and get it reapplied by a pro. But I know that can be costly. I got quoted $300 to repaint the hood, roof and one side panel with an enammal paint... :-\
Andrew Fanshawe
04-04-2017 12:51 PM
RaceDiagnostics
09-13-2015 02:22 AM
jagent
09-12-2015 09:10 AM
