How do I disable my automatic headlights?
Wait a moment. I know what the problem is. Your lights are switching on/off without you controling them and even when you switch it off manually you still get green light on your panel.
What you need to do is use your NAV screen (if you have the big screen), go to menu, then choose settings and go to daylight switch , once there switch it off (it is on right now). Once you do that OFF means OFF and then if you set the switch on auto (recommended) it will then be OFF unless it is dark.
Do that as soon as you can because having the lights always on will burn the HID Xenon and these are not cheap to replace.
Let me know what happens
