Intake Manifold Polish
Well I started with removing the rough surface with grinder, bad idea I had to work more because of this. Then I use a drill bit attachment on my power drill, had to be careful because if I angle it wrong the drill would hit the intake and scratch it I decided that the best way to go is to us a double wheel sander and small places a dremel. I still need some more sanding with fine grit sandpaper and some edge work but I think it looks better. I am also waiting for the supercharger plate being fabricated for my car I decided on a Vortech. I will keep you posted on another post about that.
If you don't want to do it yourself check these guys out the are awesome
www.mirrorfinishpolishing.com
Thanks Cadillac
Thanks Cadillac
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
