No front fogs
The 08 S-Type had an OEM foglight kit available from the dealer. Problem with that is they end up blocking the oil coolers behind the the fog-grills. You might be able to make it work if you switch the duals over to the 03-04 single cooler assembly, but that might be a bad idea. Jaguar changed over to duals for a reason. If you try this out though, make sure you post up & let everybody know how it goes. Hope that helps. And check Nally Jaguar for parts if you get them. Think we get a 15% discount & free shipping as forum members, since they're sponsers.
rsa760041
23
09-25-2015 01:33 PM
1964Daimler
09-09-2015 11:28 AM
