Rims Advise
RE: Rims Advise
Here's some available choices, both 16" and direct fit on your XJ6
1994 Jaguar Kiwi wheels
1995-1997 Jaguardimple wheels.
[IMG]local://upfiles/3394/4CF218D0D2EC4CCDB2B3B458AEF27E4B.jpg[/IMG]
[IMG]local://upfiles/3394/18CD23BBD6404C049A76B9ACE07FECD9.jpg[/IMG]
[IMG]local://upfiles/3394/85B035D28D0844ECBA80DBD5E0B903FC.jpg[/IMG]
RE: Rims Advise
You may also try 1993-94 XJ12 wheels , they're 16"
[IMG]local://upfiles/1277/5F1ACAECAB3540FEBAA66EBDBE285622.jpg[/IMG]
and see my post at this thread :
https://www.jaguarforums.com/m_90068/tm.htm
RE: Rims Advise
20 inch will fit take a look at my xj6 here
http://www.garaget.org/?car=123236
did some mods though but the rims where wide and whith big tuires if you use 8,5x20 whith 225/30/20 you wont have a slitest issue
Look at dp motorsports for wheels
jaggachafen What wheels are those? They are so bad ***!!!!Give them to me!!!! lol Seriously could ya tell me what they are so i can copy you
I would advise you to go to reputable tire shop and they will be able to tell you how big you can go. The rule is simple the total diameter of the wheel and tire should stay about the same all you are changing is the tire to wheel ratio, meaning more wheel less tire. I would also tell you to watch the with of the new wheels as wider wheels can cause rubbing in the wheel wells and possibly the outer fender. I hope this helps, keep us posted
Marque
10-11-2015 05:59 PM
