Tyre Valve Caps
Received 9,011 Likes
I bought a set like the ones you're showing JimC64, but in white. They're great! I was hesitant at first because they were coming from China, but they took no time at all to get, and it came with a nifty Jaguar keychain wrench to tighten them on.
I bought mine off of ebay, the seller was rainbowgift2009.
Cheers!
Rob
Cheers!
Rob
Nice Spitfire
Being a Patriot I have the Saltires ( as below ) on my A6...Love them and also have a spare set for future. These have an anti theft system incorporated, its a little set screw that once the valve cap has been tightened is locked right up to prevent the kiddies from removing them for their bikes
On the wheel
Hi Spitfire, lovin the pics of the rims with the Jag tyre valves They're really classy, yet understated at the same time..Nice one!
The New Jaguar growler centre caps really help to finish off the rims which also seem in top notch condition......Beautiful
One thing I noticed and a small criticism, that I hope you don't mind....
I was surprised to see that someone who obviously takes great care and pride in their vehicle as you obviously do has wheel balance weights on the outside of the rim?
If I were you I'd get those removed immediately and rebalanced with the weights on the inside for an even better / cleaner look.
If you do decide to go down this road please, please be careful as there is a very good chance of damage as you remove these weights....another reason for them being on the inside.
Thanks for sharing the pics of the rims with the valves and centre caps
Jim - I couldn't agree with you more! The weights were on the outside when I bought the car in January and the first thing I thought was that whomever put them there should be shot! I am a bit fearful when they're removed as i don't know what condition the rims are underneath. I am going to have them moved to the inside in fairly short order.
I've got a fair bit planned in the tire department. New slotted, cross drilled rotors are on my list, as are ceramic pads. The amount of brake dust the current pads are generating is driving me crazy! I also want to take the tires off so I can clean the inside of the rims and paint the calipers.
Question - given the look of the car and tires, should I paint the calipers black or silver?
Rob
Rob
Those type of balance weights just unclip so you should be OK.(just make sure it is the tyre shop that removes them) I hope. I have always used Flat alloy wheel balancing weights with alloys which stick onto the horizontal flat part of the exterior of the rim and are fairly unobtrusive.
But I have pretty much always had to weight both interior and exterior sides to get it right. (I'm lucky in that my local garage owner is a longstanding friend, who allows me to use all his kit, with the proviso that I give him a lift if he is a bit pushed from time to time.)
Black would hide them, IMHO silver = tacky, although why not red?
Like the valve caps, as a legacy from my L/R days I still have my L/R caps on the old XJ.
Cheers,
Cheers,
Hey Spitfire, the cross drilled rotors and ceramic pads will make the car look even more awesome when done, and I've no doubt you'll do a great job, maybe even a write up with pics to show it off some?
What pads have you decided on? EBC Redstuff / Akebono?
I've included a few links below that you might find interesting Spitfire?
painting_calipers_n_hubs_for_the_mondeo
A6_painting_hubs_n_calipers
unrelated_but_u_might_find_intersting?
As for the colour of the calipers Spitfire, essentially its your car and your choice, but here's my observations for what they're worth.
Your car looks like a really clean, loved n looked after example that is slightly upgraded here n there but more or less looks stock - thats the way I see it!
If I were you I'd paint the hubs before fitting ( silver to match the inners of the alloy / rim and to stop the rusty/grimy look from wasting the overall look. As for the calipers? Again I'd go for silver (just a really clean, but stock looking finish ).....If you do decide to go for the EBC Redstuff pads, you'll get a tiny RED flash off the pads against the calipers with the black wheel wells and clean blacked tyres giving a really clean sexy but stock look.
Just FYI I fitted EBC Redstuff to my X type and they offered excellnet stopping power combined with much reduced dust too...All good
Whatever you decide, I'm sure they'll look great when finished and hope that you decide to do a write up with pics for the site
I ordered one as well.
Thanks for the tip.
Thanks for the tip.
Cheers!
Rob
Cheers!
Rob
