F-Pace (X761) / C-X17 2016 - Onwards
2016 F-Pace every module not working
Old 05-21-2024, 05:21 PM
AriesKcar's Avatar
Default 2016 F-Pace every module not working
Got this 2016 jaguar F pace every module is throwing an error voltage is all over the place any ideas what's going on?
https://youtu.be/YET6ikkMV8c?si=Hi-uMN11VfoQkD7o
Old 05-21-2024, 06:34 PM
XKDreams's Avatar
Welcome, from a newcomer.
Low main battery voltage. Take it out, fully charge it, and take it to a competent auto parts supplier to have it load tested. If good, reinstall and make sure all the connections are clean and tight.
Old 05-21-2024, 06:48 PM
AriesKcar's Avatar
I took it for a ride and when I got back the voltage was as low as 12 V with it running do you think the alternator could be bad or is it computer-controlled? In the video you can see it even hits 15V
It refused to start for a few minutes said the transmission was not in park and I was not pressing the break but I was.
If the battery is bad do I have to program it like BMW?
Old 05-21-2024, 09:23 PM
XKDreams's Avatar
As my previous post…get the battery tested. Hen have the alternator output tested.
AriesKcar (05-21-2024)
Old 05-22-2024, 02:30 PM
AriesKcar's Avatar
Replace the battery with a brand new one no change it has these 2 codes at the start which might be a failing module that's springing the whole system down does anyone know where this misting sensor is?
Old 05-23-2024, 01:04 PM
clubairth1's Avatar
Received 2,365 Likes on 1,863 Posts
Those are minor codes and I would erase everything and drive some more to see what codes do come back.
Please post the exact battery you installed.
Old 06-05-2024, 03:31 PM
XKDreams's Avatar
@AriesKcar helloooo….whats happening with your problems?
F-Pace33
04-22-2022 02:33 AM
Jaguar Forums Editor
12-21-2016 08:15 PM
Wolfy
05-24-2016 06:33 PM
Eurobahn Jaguar
04-14-2016 08:39 AM
rav1up
12-14-2015 05:50 PM
Quick Reply: 2016 F-Pace every module not working
