2017 f-pace 2.0 front radar sensor blocked?
So my f-pace showes a warning front radar sensor blocked on the dash which shuts off the cruise and auto braking. I purchased this car with a busted grill looked like somone backed into it. The sensor was popped out of its bracket but no visible damage. I snapped it back in and everything worked with no grill. I now have a new grill (aftermarket) and I get the sensor blocked message?? I can’t believe the grill would make a difference so assume the sensor might be the issue? Any ideas? If I get a new or used sensor will it need calibrated or can I just swap it out! I am about 1 hr to the nearest dealer so hate to take it in just to be told it needs a sensor and then bring it back again…
Also I have a aftermarket grill would this have any effect? The center section of my grill was half missing when I got it, so I have no clue if it was all honeycomb or not but I see some of the grills have a rectangle which would be in front of the sensor? But my sensor is mounted in a bracket right in front of the a/c condenser about 3 inches behind the grill, it is not mounted to the grill? My new grill is all honeycomb.
Received 6,310 Likes
