The ambient lighting in the center console around the shift knob stays blue and isn't changing color. Also, the LED light on the right side isn't working. Not sure if these two things are caused by one problem.
Is there a way to replace the LED light?
Thanks in advance.
Peter The two connections. The led on the right isn't working. Not sure how to fix this.
I haven't checked online parts sites to see if it's sold separately, but the LED itself does appear to be a replaceable assembly (light tube with wiring harness that you plug into car).
