Android Auto
Creeping about, joining you from the f-type side of things. Trying to discover all the settings on my 2019, I finally found the connectivity menu where you're supposed to be able to pair your Android device and set the settings.
If I am seeing a pop-up that says "connect a compatible device to view settings" whenever I touch the "Android device settings"/"set preferences for Android devices button", that might mean they have not turned on the capacity in my car? Or is there some other arcane information I am missing?🤔🤷*♀️🤷*♂️
Android Auto and Apple CarPlay are only available on ICTP systems and require a software update to at least 18B. Once updated the dealer will need to enable the Smartphone Pack for AA and CP support. Some dealers may want to charge $300ish to enable, others have enabled for free.
Have you had the Smartphone Pack successfully installed? If not, do you know anyone that has?
I had 18C installed with the SmartPhone pack enabled at my 2nd annual service in January and have been using CarPlay for almost a year. With the latest ICTP update of 19B the SmartPhone pack should be enabled by default. Also, those with 18B or better may start seeing OTA updates in ICTP for updates to the 19B release.
Unoplop
08-01-2024 05:55 PM
JustBlessed
XE ( X760 )
11-17-2019 01:13 PM
hratzlaff
XE ( X760 )
27
07-31-2019 03:17 PM
Uncle Fishbits
06-20-2019 12:28 PM
