I want to permanently connect my CTEK using the "comfort panel" (silly name!) in the boot space so that I can connect the CTEK conditioner without having to access the battery area. I have done this on my F-Type connecting the positive to the Bus panel above the battery and the negative to the body.
I have the instructions for the F-Type panel but not the F-Pace and the cables are different, does anyone have a photo and diagram for connecting? Top
Thanks but I prefer to connect the positive to the Bus Bar as per the fitting instructions for the F-Type, unfortunately the wiring is different. I would like to have a copy of the Jaguar fitting instructions for the F-Pace. See photo of Comfort connector to be located in the load space.
I haven't seen any Jaguar instructions for the F Pace. I'm not home, or I'd take a look and try to sort it for you, if in fact our batteries are set up the same. Connecting to the bus bar is for convenience only, as it is directly connected to the battery. My F Pace and F Type are connected directly to the positive terminal of the battery, and the same on my motorcycle. The CTEK connector is no different than any of the other battery charger connectors.
