Brakes and rotors on new F Pace
Received 2,193 Likes
If rear thats about average for light brakers. The bias is more rear for light brakers to reduce front end dive. Heavier gets more front. I would ask where theyre at because i will recommend if theyre close so you dont leave and then a short time later the pad sensor comes on for the "what i just had it in for service work. Why didnt they just do them then?" complaint.
And normal usage is purely subjective to the driver. Followed my ex wife to work one morning and counted the number of times her brake lights came on. 35 times to my 3. I keep distance and take my foot off the gas and cover the brakes but dont use them unless i have to.
On your rotors they may or may not be below minimum thickness, and might be below before the second set of pads need to be replaced. while i use to replace pads only many times, I quit doing that for too many returns complaining about brake noise. You may just be able to do pads but thats your descision then.
I've moved your question from General Tech Help to F-Pace forum. This is the place to post technical questions about your model.
because they took off the rotor protection bags that are supposed to be left on till sold. When a car sits and humidity and rain make the rotors rust except where the pads sits. Now when driven the rust is cleaned off when braking, but now where the pads sat there was no rust and those spots are now thicker slightly and cause brake pulsating when braking. This is acutall the biggest issue with brake shimmy not out of round or warped rotors. Its excess paralellism
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Anyway, once the dealer got it back for a full service & check up, they had to put a complete new set of tyres on (flat-spotted) and a new battery in it. I made sure oils were changed too as part of the service given it had been sitting unused for two years. Barmy.
I've not detected any problem with the brakes though which is a bit surprising as it was stored near the sea. Touch wood no problems there although there are still 2 years left on the Warranties. Only other issue I've found is the Navigation software out of date - the Aus/NZ update isnt available online, so the dealer will have to update the SD card. The F-Pace is a nice step up from my old 3.8 Supercharged Calais.
Received 3,231 Likes
I've just bought a 2017 F-Pace S which had only 80kms on the clock when the dealer picked it up !!! It had apparently sat in the original owners garage since he bought it while he drove around in a little Suzi. He is apparently trading up to an SVR - hope he drives that.
The following 2 users liked this post by OzXFR:
AlexF_PaceS (07-22-2019),
Tp10XKR (10-31-2019)
John Jones
05-21-2018 05:51 AM
tomas6791
F-Pace (X761) / C-X17
05-02-2016 12:11 PM
