Check engine code help
I posted this in another thread but was suggested to come over to this section. Hopefully y’all can help.
I recently purchased a 2017 Jaguar F-Pace 35t R-Sport. Check engine light has been on. Comes up with 2 codes:
p008a “Manufacturer Control”
p2541 “Low Pressure Fuel System Sensor Circuit Low”
I’ve inspected/tightened gas cap, added a bottle of Seafoam and a full tank of premium to hope try the simplest fix first. I erased the codes and immediately returned after driving it once. I don’t notice and performance issues, shaking, rough idle etc.
After combing the internet, it seems to come down to possible fuel pressure sensor, fuel pump, fuel filter.
Most videos online show diesels being worked on so it’s hard to locate these items I need to check. Any feedback on what is most likely the cause and location of where to check would be appreciated!
Thanks in advance,
Bryce
Thanks in advance,
Bryce
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
check the live data for the pump and sensor on a scan tool and compare with break out line to a gauge on the low pressure fuel line.
If everything checks out do a fuel volume test for flow.
Or take it to a shop.........
