first of all, sorry for my bad english. To order a Beer no problem, but explain the p
roblem I have with my F Pace big problem.
I try it anyway. Maybe I get some help here.
Since a month my Engine light turns on. I checked it with my Maxi Link. P049B
I can reset the problem and when I drive on the Highway everything is fine. When I drive slow, After some miles the light will go on again.
I used google and some people said that you have to clean the Egr Filter. But, where is that Filter located?
I am driving a F Pace 3.0 Diesel.
Any other suggestion?
Thanks for any help.
I'll leave it to members with the 3.0D model to advise on the procedure but here's the location of the EGR valve:
A quick check of the Workshop Manual indicates there's an EGR valve on each side of the engine. Also from the manual, here's the relevant description of the P049B-00 error code showing possible causes and actions:
Hello Uwe,
how did you solve the problem? I have the same problem as you. I saw on YouTube o’Reilly autos explained that this can be caused by blocked DPF, which make sense. In my case DPFwas regenerated but still got this trouble code. Could be anything as in attached explanation above.
