F-Pace Coolant Leak - Help
Looks like a cooler. So if it’s dripping out of one of the hose joints then you probably have an o ring leaking at the connector or it’s the connector/hose itself. That can be easily remedied and much cheaper than replacing a cooler. Alternatively it’s leaking further up the hose and just running down and dripping off the lowest point. If it’s pink or orange color it’s definitely coolant. Go to your local dealership. Good luck.
