F-Pace - radiator pack replacement
hello everyone nice to be on the forum for the first time, i have a 2016 f pace that had some damage to the radiator pack which i have now replaced. can anyone tell me what would be the total amount off water & coolant it should hold to refill the complete pack?. i have put in around 3-4 ltrs. but not sure if it is full through the entire system it didn't seem to take very much . how can i check this ? and what do i need to do to be sure?
many thanks for any advice in advance
Welcome to the forums Nisignco,
Capacity depends on the engine fitted to your vehicle.
COOLING SYSTEM CAPACITY
3.0L Petrol - 7.7 litres
2.0L Petrol - 9.05 litres
3.0L Diesel - 9.2 litres
2.0L Diesel - 7.7 litres
SPECIFICATION
Mixture of 50% water and 50% coolant meeting JLR specification STJLR.651.5003
When I've had the cooling system 'open' to replace a hose, water pump etc:
1. slowly fill to the MAX mark on the reservoir
2. refit the reservoir cap
3. run the engine up to temperature
4. check for leaks
5. allow the engine to cool completely
6. check the level in the reservoir
7. top up if necessary
Enjoy the forums.
SPECIFICATION
4. check for leaks
Enjoy the forums.
mhamilton
08-29-2022 02:40 PM
