Hi, I'm curious to know if anyone has fitted OEM Jaguar rims from other models to their F-Pace. I recently purchased a set of Jaguar Kasuga rims for my dads XJL for winter use, but he decided to store it away, my xf will also be stored away for winter.
My mum has an f-pace s, with 22 inch double helix rims that are not ideal for winter (neither are 20 IMO), since the winter tire replacement cost is going to be significant and I rather not swap out tires, rather rims with separate set of tires mounted on them
QUESTION: will Jaguar Kasuga rims fit okay? They have same bolt pattern used by all modern Jaguars.
They measure 20x9, offset 49 (front)
20x10, offset 46 (rear).
I'm planning putting a set of 255/50 r20 (front)
285/45 r20 (rear)
Any opinion and feedbacks are welcome and appreciated,
Cheers! Not a fan of the black colour wheels in general, but they do look quite nice off the car. These are staggered rims
@Zereldo
Sorry, I can not be of help. Just to say you are not alone getting 'zero' response on this forum.
If you want response, try the UK forum, but properly introduce first please..
@Zereldo
I can only be of help by uploading the list of tyres/rims that JLR gives out.
Check it if they fit or not, but then still check with a tyre fitter since they see this everyday. If the car is to heavy for the wheel you can get in a bad accident.
285/45 r20 (rear)
not sure about the rims you mentioned but, I have put in several rims, some even from Ford. The offset I I rectified via spacer but ultimately stuck with the double helix. To be honest, with the BP of 108x5 you are severely limited.
