just purchased a project 2017 2.0 diesel, has egr issues?
So I purchased a project 2017 F-Pace R-Sport 2.0 Diesel, i got this at Salvage auction and didnt really look real hard at it, turns out it has some engine issues not just the accident damage i had seen. so to start I am a Audi Tech, but my wife likes the looks of the Jag so figured I would give it a try, but I am no diesel tech at all. What i know is the glow plugs were unplugged, and the EGR cooler and egr valve were unbolted from the intake. i plugged in all the electrical and it fires right up, and sounds good, but wont move under its own power and stalls out. after about 30-45 seconds it blows out massive smoke from under hood, and what looks like very black Thin dirty oil from the egr that is unhooked. Later I bolted the egr back together and now it wont start, it tries but no go, assuming the oil/mess from egr is going into the intake.
Codes the car shows are P20E9-85 Diesel exhaust fluid pressure too high, and several codes my snap on scanner doesnt know. 40B62H/265058 (refer to OEM repair info) and 40D17H/266495, and 238117H/232680. I cleared the codes and none came back but then again it now wont start, after a few tries it sounds like its becoming hydrolocked so I quit for today.
any ideas on where to start? could the Def blue system be at fault?
thanks
thanks
Well turns out it was much simpler then I was expecting! Turns out it was just a bad turbo! Turbo was seized and was pumping oil directly into the intake! No air would go thru at all. Someone had removed the egr so it could breath a little and start. But ended up filling the intake with oil! Cleaned it all out. Replaced the turbo and runs perfect now! Simple fix but a pain to clean all the oil out!
XKDreams (05-21-2024)
I was shocked! I am an Audi tech but not diesel! I have never seen a turbo that would not let air flow thru so I wasn’t thinking turbo at all! I did run a camera down the exhaust and was also shocked it was clean no oil at all, but I had to pull the injectors to get the oil out of the cyls. Cleaned the intake and inner cooler. So far all good!
