Key fob 'Place Smart Key as shown and press Start' issue RESOLVED
First time poster here and appreciate any insight into this issue I'm having with the key fobs (both). I have the dreaded "Place Smart Key as shown and press Start" message and I must do so in order to start the car. The most frustrating thing is I've fixed this before and now the same fix isn't working again. Here are the symptoms:
- I can lock the car by touching the external finger "dimple" without issue.
- I cannot unlock the car in the same way; it must be done by pressing the key fob unlock button.
- I cannot start the car with either key fob without placing on the physical contactor on the dash
- Replaced both key fob batteries, twice (each).
- Tried multiple combinations of having the driver door open, key fob in the car, press start but not ignition, with ignition, etc.
I appreciate the insight and was definitely worth a shot. But with the heat wave in the U.S. right now I didn't feel like being outside messing with the battery, so I instead went the pull-a-fuse route. It worked! I'm going to edit my post above to help the internet crawlers in the future ;-). Thanks again.
Never mind, I guess I can't edit my original post.
The solution was definitely power related and @BritCars' suggestion led me down the path of opening the passenger fuse panel and pulling the 5-amp F35 fuse and putting it back in again. There was a definitive electronic click sound from a relay (I assume) and that was it - keyless entry and key-in-pocket startup has been restored. Thanks again.
jp0928 (07-29-2023)
Bulldog
General Tech Help
01-20-2020 03:35 PM
car5car
09-14-2016 08:41 AM
