Mirrors Folding
I put together a list of the dealer configuration back in June while "patiently" waiting for ours to arrive.
Here's the complete list....
F-Pace Dealer Configuration Items
Passive arming
When the passive arming feature is enabled, it automatically arms the perimetric (exterior) alarm system 60 seconds after the driver's door is closed. All of the other doors, the hood, and the luggage compartment must also be closed before passive arming enables. The ignition must also be switched off with no valid smart keys inside the vehicle.
Passive arming does not lock the vehicle, although access to the luggage compartment, via the interior or exterior release switches, is prevented.
Daytime running lamps
With the lighting control in the OFF position or in the AUTO position, while the lighting conditions do not require the headlamps to be on, then the Daytime running lamps switch on automatically under the following conditions:
1. The engine is running.
2. The gear selector is out of Park (P) (automatic transmission).
3. The Electric Parking Brake (EPB) is not applied -market dependent.
Speed-Dependent Mode
If the vehicle's speed drops below 5 mph (8 km/h) with the wipers operating, the wipers switch to the next lowest speed. When the vehicle's speed increases to over 5 mph (8 km/h), the original wiper speed setting is restored.
Vehicles without a rain sensor fitted also increase the frequency of the intermittent front wipe when the vehicle's speed increases.
Drip Wipe
If the drip wipe function is configured, the wipers operate a few seconds after a wash and wipe cycle has finished. The drip wipe function clears any remaining drips from the windshield.
Auto Mirror Fold
The mirrors can be configured to automatically fold when the vehicle is locked and unfold when unlocked.
Passive arming
Drip Wipe
Auto Mirror Fold
DPK (01-30-2017)
I went to the Jag dealer and my tech buddy tried to disable the Auto-Fold feature and couldn't do it..the program option is there, but it yielded no results.
Options: under auto-fold mirrors
Not fitted
Manual Power fold
Auto power fold
Tried them all, nothing changed..except when you select "Not Fitted" it will turn off the Power fold manual method.
Not fitted
Manual Power fold
Auto power fold
