No wheel lock key? Any ideas?
So this f-pace I just, got turns out there is no wheel lock key? Has anyone had luck getting one? I called my local dealer expecting I could order one by VIN, but they told me can’t get one and I need to schedule it in for them to remove them and then replace all the lugs with a new set?
If you are in the states, try your local tire and wheel retailer like Goodyear, Firestone, Tire Discount etc. If they can't help you, then the Jag dealer is your only option. If you got those out, throw the locks away and buy a regular wheel lug nut. Thieves don't steal alloy wheels anymore because it takes too much time to steal all 4.
The wheel locks are aftermarket McGuards. The key should be in the trunk in the foam surround. There’s a spot that it sits in.
Failing that, grab a long socket set and find one that just barely almost fits over the keyed lug nut. Bang it on with a hammer and then back it off with a breaker bar.
Yes, do it the earliest. Your worst nightmare is having a flat in the late evening or the wee hours and you cant get that thing off. And also check the spare regularly (at least once month) for the correct tire pressure. Your worst nightmare as well, if your spare is also flat.
send me a picture of the lock that you need.
