Oil Level Critically Low Warning 2.0 Diesel
Hi Everyone,
I have 2017 2.0L Diesel F-Pace that has recently started showing "Engine Oil Level Critically Low" warning light once the vehicle has come up to temperature (driving for about 30 minutes) only when I come to a stop. But disappears again when I start driving.
Now... the 2.0L Diesel has an actual dipstick, and my dealership says it doesn't actually come equipped with an oil level sensor (nothing available in the vehicle information menu). So it is a mystery light. Oil levels have always been fine on the dipstick, and the oil was just changed the other day and the dealership says that that light would have been about the "quality of the oil" because it was a little bit past its service required time and should now go away because the fresh oil change. This didn't make sense to me as the light is a critical warning.
But of course, driving it again now after the oil change I still get this light coming on.
Anyone else with this same setup seeing this warning light?
"my dealership says it doesn't actually come equipped with an oil level sensor"
Well then, how can it give you an error message if there is no sensor?
Have an independent mechanic put the car on a hoist and look to see if it has a sensor attached to the oil pan (https://www.ebay.com/itm/163537242270). If it does, then it may need a new sensor or the wiring connection may just need cleaning.
Here are the part numbers:
FORD OE NUMBERS 8W936C624BF, 8W936C624BG
JAGUAR OE NUMBERS AJ812432
LAND ROVER OE NUMBERS LR012640
If you do need a new sensor prices vary considerably, so shop around for the best deal.
Stu
Stu
Welcome to the forums brcwane,
Jaguar specifications vary across World markets so it's never sensible to be dogmatic but the oil monitoring on your 2.0D is likely to be the same as on my European specification 2.0P.
LEVEL is checked only by dipstick and there is no electronic system to display level in the Instrument Pack as there is on my XK.
The only red oil warning lamp is for PRESSURE as explained in the Owner's Handbook but doesn't come with that message!
It's a suspicious coincidence this has happened after a recent oil change. The attributes measured for the oil are:
1. level
2. pressure
3. temperature
There is no way the "quality of the oil" is measured.
The only sensor I can find that may be a possible cause is the Oil Pressure and Temperature sensor (see item 5) in the base of the oil filter housing:
However, this still doesn't explain the message.
1. level
2. pressure
3. temperature
Thank you both for your responses!
It was happening well before the oil change, and even after the oil change the light comes on. So it is definitely not the oil level that is triggering the dash light.
Agreed, I went through my owners manual and nothing there. Just like the post above, only the dipstick and no sensor according to the documentation. So the message is really strange. If it was oil pressure you would think the oil pressure light would come on.
They left a message stating that they also "think" that it could be a sensor in one of the oil pumps that is causing the message. But my reasoning still stands.. why is it an "Oil Level" warning? It makes no sense and I'm really not in the mood for swapping out parts hoping it fixes the problem that they can't diagnose. Especially when the dealership charges $300 in labor for doing an oil change LOL
Like you, I wouldn't be letting the dealer go on a 'fishing expedition' with my bank account and throwing parts at a Jaguar is neither logical nor cost effective..
A search shows this topic comes up on several forums for Jaguar and LR models using the same JLR 2.0 engine. Plenty of discussion but no definite cause/resolution. A diagnostics session with JLR Pathfinder could throw up relevant error codes or one of the software updates could be the answer.
Thanks for all the responses. @GGG I'm assuming a diagnostics session when the light is lit should hopefully tell me what the issue is. .....
Ok... some updates.
They replaced the Oil Pressure sensor (JDE40662) as pointed out by @GGG and the light comes on intermittently now when I stop at idle after the engine has come up to temp. Sometimes comes on, sometimes doesn't.
They connected the data logger for oil pressures and it showed 145KPA at idle.
They said that if that new sensor doesn't solve the problem it likely needs a new oil pump as outlined by @Rummy636
What kind of labor does a typical oil pump replacement look like? The pump itself looks like about $500'ish dollars USD
Ouch!
I started going through the Workshop Manual and replace oil pump referred me to replace oil pump chain which referred me to remove oil pan which referred me to remove front subframe ......
Definitely an itemised quote required before letting anyone loose on this.
The crappy part is that I can't really trade it in with a problem that is likely thousands of dollars in labor to repair and a error light showing up on the dash.
GGG (06-23-2022)
Afternoon,
Did you ever get anywhere in terms of resolving this issue? I have "exactly" the same light with precisely the same symptoms, i.e. engine is warm been driving for 45mins, the minute the engine goes idle "Oil Level Critically Low"
Oil levels are perfectly fine and this only occurred after a recent MOT test (passed btw) but prior to that I had never seen this before!
Took mine to the same garage for troubleshooting and they couldn't find anything, recommended a fresh oil change at £300 "MAY" resolve the issue, politely told them I'm paying for guarantees not hopes
Going to get a second opinion this week but was curious on your outcome?
Mark
Mark
Afternoon,
Mark
Mark
Hi,
Is anyone solved this issue,
I got the same warning today on my Jag F-Pace 20d. Leave it cooled down and checked the dip stick - the oil level is fine.
So I would like to know what is the suggestion, just ignore it, troubleshoot or sell the car ))
Is anyone from Jag respond to that issue?
cchong
10-28-2020 10:57 PM
dmukic
10-26-2019 10:49 AM
tiouis1964
05-09-2019 04:12 AM
