Anyone knows where the coolant pump relay is located? Getting this OBDII fault but can't seem to find where the actual relay is located. Probably inside another component?
2018 F-Pace, 3.0 S/C
Let me start by stating I don't have a 3.0 but I do have a 5.0 XK with the coolant pump and Jaguar tend to apply similar design across the model range so the XK description may help get you started.
The DTC lookup gives the same possible cause description:
There is only the one extended code for P2600 so no other codes or possible causes.
On the XK, the relay is in the Power Distribution Box. No reason to think F-Pace will be different. Not many relays on modern Jaguars so it shouldn't be too hard to spot.
Thank you for the information. So far I checked the relays that are located in the engine compartment fuse boxes, all seem to be clicking. I bought a service manual which describes the coolant pump relay as R12, but unfortunately it only shows me a wiring diagram.
