Service reminder light
Hello, the service reminder on my 2017 3.5 supercharged came on at 23000 miles, took it to the dealer since it had a service contract, they said service was not needed until next May 22, and added that those service reminder lights do come on randomly and should not be trusted. I think that is BS. What do you think?
I think, they can do the reset but don't have the time to do it.
But you can do it yourself,
This is what I did to mine to reset the Service Service Required Warning Light
1) Driver side door open & Hood/Bonnet raised open
2) Turn On by pressing the Start/Stop button without your foot on the brake pedal
3) Step on both the gas & brake pedals all the way down until you get the confirmation the warning light has been reset. I think it takes about 10 secs. Just follow the instructions on the instrument panel. When you see press OK that means it's done.
Byte Me (01-25-2022)
is there only one service light with jag?
there can be 2 - 1 for an engine service and 1 for more of an inspection service - brakes etc
on audi the inspection is a set interval i believe, on BMW its very cleverly pre-programmed, and why fitting OEM parts is important, they are designed to a certain spec to last a certain time so the light will come on based on that. I reset my inspection light after checking all was well.
A year or so later i got the brake pad light tripped by low pads only to discover that the sensor is separate and can be reused if not tripped, however i did wait for it and it needed replaced at the same cost as the pads!!!
I guess what i am saying is the lights are not random - to ignore lights in modern cars can get costly.
Best bet go to an indie and see what they say, they depend on their reputation, cant hide behind a big sign....
ugotmale
05-21-2015 02:14 AM
