Warning light
Does anyone know how to reset the warning lights in the F-Pace. I have a 2019 F-Pace SVR and recently hit a pot hole so bad that my car thinks it had a suspension issue but it doesn't had the checked over. My shop for some reason couldn't get the sign to turn off so I am wondering if I can do so myself? Also because the Jaguar dealerships are currently closed in NJ.
If the warning light is on,there is a problem and there will be a code that tells you what part of the system has a fault. Just looking at the suspension won't tell you where to look for the problem. Does your Tech not have a code reader? Most readers will also reset warning lights, unless the problem is still there. It could be something as simple as a disconnected or broken height sensor, or something more involved like a damaged shock.
I will have to ask him again I would like to just get rid of the sign but Jaguar is currently closed so I just have to wait it out. Hopefully its something very stupid like a lose wire or something.
Jaguar Forums Editor
Jaguar Press release
03-25-2019 04:12 PM
Austin7
F-Pace (X761) / C-X17
37
02-06-2019 01:28 AM
03-26-2018 10:18 AM
