Warning Light: Power Steering Assistance Reduced - 2017 F-Pace
Woke up one morning, turned the car on (It's a little cold outside), and the Power Steering Assistance Reduced Warning light came on. I can't seem to find any documentation on it.
Anyone have an idea of what may be going on? I wonder if there's anything I can check or clean?
It is electric power steering, so with the colder weather, and you no doubt switching on seat and steering wheel heaters etc, the power management system has decided to restrict the power available to certain other power-consuming installations. Did the warning disappear when you moved off ?
Timotitoju (01-26-2020)
Hi did you end up replacing parts? Going through the same issue let me know. Thanks
I had the same issue, the mechanic replaced the alternator and the problem went away for about 98%. He's suggesting that we change the battery too and then the problem will completely go away.
Hope this helps
Hope this helps
sunchip
01-28-2015 08:21 AM
