What you DON'T LIKE about your F Type
There I did it. I let the cat out of the bag. But as much as you may love your car, I'm sure there are some quirks about it that you don't like. But this thread may also serve as a way of troubleshooting an issue if one owner is experiencing it and another owner has a fix.
It will be helpful if you state the year, model, engine and packages
I'll start.
2015 F Type Coupe Base/V6. Performance Seats, Premium Pack, Climate Pack.
-Clamshell hood: Looks cool but I dislike how I'm basically dry humping it to shut the hood.
-Stock "Sport Seats". They just look plain goofy next to the Performance Seats. We have a company V8S in our fleet and it has the Sport Seats.
-Glitchy audio system. I recently had to reformat some of my MP3 to 192kbps in order for the audio system to play them through the USB port via my thumbdrive
-Driver side seat belt loop on seat. I'm 6'3 so the hoop is actually lower than my shoulder so it causes my seatbelt to not provide the correct tension
-Not being able to see the front of the car due to the bulges in the hood. This is a preference. But due to the bulges in the hood, I can't see how close I am to a curb when I park nor can I accurately find the lines when I'm hugging the apex of a turn.
-Cheap horn sound when you confirm the car is locked. I like the soft chirp like Lexus or BMW. Again personal preference.
-NO LOCKING fuel filler cap. Enough said.
-NO coin tray
-Odd location of rear foglight switch
I'll start.
-NO coin tray
The following 2 users liked this post by WhiteTardis:
buickfunnycar.com (03-05-2015),
necoblitz (03-05-2015)
Company V8S? I want to work for your company.
My only gripes (since I don't have the car yet - V6S 6sp):
1. JLR isn't accepting production orders yet for the 6 speed.
2. You have to order several thousand dollars worth of garbage in the premium pack to get the vision pack.
3. You can't get ceramic brakes with the 6 speed.
I simply don't like that I have to wait until May to get it!
As for the fuel filler... the access to the fuel filler should be locked when the car is locked. (Or so that's that it sounded like in the manual I read. The cap itself doesn't lock, but you shouldn't be able to get to the cap if the car is locked.)
My only gripes (since I don't have the car yet):
For a car at this price, mine is fabulous and I don't have any concerns at all on a day to day basis.
2015 F type R with Italian Racing Red and Camel interior... pretty much all the options outside of pano roof and ceramics. Even the sound system is really good.
I did raise a minor issue awhile ago that I wished the rear spoiler could be manually dropped down for long highway cruising and that I could still get the open exhaust growl, but without the snaps and pops for when I am in an area sensitive to noise. However, these are not actual glitches and as far as I know other makes of cars that have these features also do not allow manual intervention.
Lawrence
Lawrence
My #1 gripe is that the car needs to go on a serious diet. With an aluminum body and chassis, there's no excuse for it weighing so much more than a C7 or 911.
EDIT: I wanted a car with no options and as light as possible, and I did the best I could with what was available.
Maybe it's all the glue and rivets. I watched the "how it's made" video and I was amazed that everything is GLUED and RIVOTED together...
-No need for automatic up and down center vents
-No need for power seats. Manual seats alone already weigh a lot
-I can do without all the plastic covers in the engine bay
-Ditch the Eco Stop/Start and ditch its battery
-I can do without headlight washers
I can guarantee all that right there is about 300lbs right there.
I'll start.
-NO coin tray
I'll start.
-NO coin tray
Everything you mentioned was spot-on...especially not being able to see the edges of the car.
This is a given which is why I didn't bother listing it. I keep thinking how much weight could have been shaved off.
I'm not bothered by the things on your original list, and I like the std. "sports seats" better. I find them extremely comfortable, and I'm 6'2" 180, but with broad shoulders and a long trunk. I found the "performance seats" crowding my shoulders, and causing me to hunch them forward.
I looked for and bought a car as stripped as I could find it. The only option was "climate pack," which can't add more than a couple of pounds.
A bit gimmicky, yes. However, I like the clean dash design with them down, which one can comfortably do in a convertible quite often. I don't know where they could put the center vents otherwise and retain the same clean design.
I love the "gimmicks" because it gives each Jaguar its unique flair. The XFR had the rotating vents, the XJ had the yacht like dash, and the F-Type has the rising vents and pop-up door handles. I love the theater of it.
Great cat but I don't like:
1. Climate control. It's inconsistent at holding a temperature and the sunlight sensor is way too sensitive. Sunlight = cold air in the cabin even on a cold day.
2. Road noise - I don't know if it's the tires or the lack of sound deadening but it's too loud.
3. No voice recognition. It's 2015 and my Chevy Equinox has it!
4. No adaptive cruise control
5. Rear camera resolution
Outdated nav and poor rear cam are my biggest complaints. I also wish I could have the new center gauge design that is coming on the MY16's.
I guess it would be nice if it was a couple hundred pounds lighter but I'm still satisfied with the performance overall.
Zero complaints on look and sound.
Lawrence
BTW Stohlen, I'm right here. I'd be happy to pick yours up and personally deliver it to you. (Guaranteed 24 hour delivery anywhere in the lower 48).
F-TypeRookie (03-07-2015)
