**Oil Analysis Results IN**
Old 08-28-2015, 04:40 PM
WhiteTardis's Avatar
Default **Oil Analysis Results IN**
2015 F Type Coupe Base
-Changed oil at 6900 miles
-Sent sample of factory fill oil to Blackstone for testing
-High in metal content but expected due to engine breaking in
-Will keep an eye on Potassium next time.
The following 6 users liked this post by WhiteTardis:
BierNut (08-28-2015), buickfunnycar.com (08-28-2015), Merlin (08-28-2015), mjm3457 (09-02-2015), TXJagR (08-29-2015), uncheel (08-28-2015) and 1 others liked this post. (Show less...)
Old 08-28-2015, 08:42 PM
mjm3457's Avatar
Is here a recommendation here?? .. like first oil change should be at 5,000 miles, or some such thing?
Old 08-28-2015, 08:51 PM
Merlin's Avatar
I'll be submitting mine when I get to my first oil change as well. I find these kinds of tests to be invaluable as part of a good engine maintenance plan.
Old 08-29-2015, 12:26 PM
lizzardo's Avatar
I pulled a sample at 518 miles and figure to do it again at 5K or so. I'm planning to change the oil earlier than scheduled this first time, especially after seeing the 6900 mile results here. Not that they're bad, but metals are higher than my C30 showed at its first change (7500 miles, the recommended oil change interval for that car).
My 518 mile sample shows:
Aluminum 6
Iron 16
Copper 22
Old 09-01-2015, 05:10 PM
Tel's Avatar
Tel
Tel is offline
What does Potassium in the oil indicate?
Old 09-01-2015, 05:21 PM
TXJagR's Avatar
Potassium generally comes from antifreeze...
Here is a great independent website that actually refers back to Blackstone labs.
Engine Oil Analysis - Bob is the Oil Guy - Bob is the Oil Guy
Tel (09-02-2015)
Old 09-01-2015, 05:33 PM
I forwarded the results to one of our engineers and his comment was
"It is possible the potassium trace is from residual metal cutting fluid in the casting which remains after the wash process. The wash takes place prior to engine assembly."
We'll see if theres a drop in the potassium with my next oil change.
Old 09-02-2015, 04:02 AM
Tel's Avatar
Tel
Tel is offline
All understood - Thanks.
Just pricing up UK analysis centres...about double the price you guys pay :-(
Old 09-02-2015, 10:32 AM
lizzardo's Avatar
On my C30 I was trying to verify that the specified 7500 mile interval was OK, so I was taking a sample at 5000, and again at 7500 when the oil was changed.
I had a sample that showed high potassium at 5000, and Blackstone suggested testing for coolant leakage. No signs were found, and when the same oil was retested at the time it was changed (7500) the potassium was gone. Our best theory was that there was some contamination in the sample. I'm not sure how I managed that, since I'm a pretty careful technician, but maybe the tubing I used to draw the sample had something in it.
LilaJagHubby
US Lower Atlantic
03-01-2017 10:20 AM
ArtyH
10-02-2015 11:39 AM
Lawrence
XJ40 ( XJ81 )
10-01-2015 08:36 AM
caldoofy
09-28-2015 08:43 PM
Quick Reply: **Oil Analysis Results IN**
