*Oil Debate*5w-20 WSS M2C925-A OR 0w-20 STJLR.51.5122
This is straight from the repair manual for the V6
I'd rather run the 5W-20 as it comes in the WSS-M2C925-A spec by Mobil 1 and Motul, both brands I've used regularly in my previous cars. Its also cheaper and readily available.
The 0w-20 STJLR spec...created for fuel consumption? I doubt that there are engineering differences in the engine from between model years that require the 0w-20 especially since the sidebar indicates that both weights can be mixed.
Probably a topic thats been discussed before but curious as to what you guys with the higher miles ultimately went with.
I have no knowledge other than what I have been told. The oil is also, ONLY available from Jaguar dealers and not sold retail anywhere else in the US.
Castrol Edge Professional OE (Gold Bottle) is presently the ONLY oil that meets the Jaguar indicated standard. Per what I have been told, it has a unique additive package AND it has a UV Dye added.
Castrol Edge Professional OE Full Synthetic 5W 20 1 Case 6 Quarts | eBay
Is this the stuff? It's on Amazon as well.
(I know all about temp and viscosity, so no need to get the thread derailed...)
May I suggest that you get hold of the oil recommendations from
a UK market vehicle and consider whether there are any differences.
For the reasoning behind this, see the opening post of the thread:
https://www.jaguarforums.com/forum/x...idance-157906/
The manual for my 2016 R says SAE 0W-20 STJLR.51.5122
I was unable to find it at any local retailers. So I looked online and was only able to find large quantities, which I did not think I would need. So I talked to the mechanic at dealership in Portland who told me to use Castrol Edge SAE 5W-20. Not sure why JLR missed this oversight??
Will you be changing the oil yourself (in addition to what the dealer will be doing per the Jag-specified intervals)? If so, consider getting your dealer's blessing that Castrol Edge 5W-20 is OK to use in lieu of the 0W-20 STJLR.51.5122. This can be as simple as adding an extra line to the invoice after your next dealer-performed service.
FS[SouthEast]: 2007 XKR "Active Exhaust" Muffler (low miles)
multistrada74
06-04-2016 09:24 AM
MrWest
02-27-2016 01:54 PM
