0-60 times on Jaguar
What's a realistic 0-60 on a stock R AWD Coupe? I came from a Panamera GTS (4.2s 0-60) before my R Coupe and the Jag feels significantly faster. I was surprised when I saw that Jag advertises it as 3.9 seconds - seems quite a bit faster to me by the "seat of my pants" test. I've also seen magazines that show around 3.5s - is that pretty accurate for stock? Not that it's terribly important - but I've wondered what people are testing it to be (without a tune).
This is not true. You can get 3.5 out of a stock AWD R, If you shifting manually yourself and have PS4 or cup tires. If you just sit there and punch it with the shitty pzeros and let the car crappily shift for you, you will get some "crappy" time around 3.8-3.9. Which is not crappy at all
I will admit for my runs I've literally put car in Dynamic Vmax mode, but I've then put suspension back to normal and also the gear box back to normal on the menu. Then gear lever is in S with S1 selected, I then punch it and let it auto upchange, I also don't hold my car with any RPM on foot brake, how about you?
I am asking because I am so close to that 10s pass and maybe if you've found its quicker shifting manual (what rpm) and holding on foot brake (what rpm) it might just get me there as current PB is 11.1@126mph in my stock SVR with GT4 intakes (factory tune).
![Icon Eddie](https://www.jaguarforums.com/forum/images/smilies/icon_eddie.gif)
- Lithium Battery (saves a ton of weight, this was based on Unhingd suggestion, -25lbs)
- Custom Carbon Fiber Hood (got this after my car was squashed in an automated garage system, -15lbs)
- Eventuri Intakes (-5lbs)
- Velocity AP Valvetronic Exhaust (must lighter than stock) + 200-cell downpipes (-15lbs)
- Velocity AP Lowering Springs (-12lbs)
- Wortec Rotors (-46lbs)
- Velocity AP Tune (slightly modified)
- Eurotoys Crank Pulley
- SVR Fenders + bumper + side skirts
- SVR Maelstrom Wheels (-20lbs)
- Other random mods:
- Stealth Startup - Custom vacuum pump to bypass stock, so now the button actually keeps the valve open/closed, no surprise opening and closing, this also allows the car to start with valves closed which was important given my extremely loud setup.
- Lighted Jaguar kick-plates
- Vinyl asymmetrical red-stripes
- Clear bra - Entire Front
- Escort CI 360 Laser Jammer + Radar Detector
- 1-touch Convertible Open/Close + Activate from Keys (mod4cars smarttop)
- Blackvue front+rear camera
- Custom Engine Cover
- KP Technologies Electronic Beep Module (so the car sounds luxurious
What do you find is optimal shift point?
#28
Eurotoys (12-19-2018)
#30
#31
I haven't tried the adjusting the gear box and suspension to normal, I will give this a try today (see if that makes a difference). I thought the car would shift optimally for me, but it wasn't the case, it was always shifting late, as if even the car wasn't expecting the power came on so quick. This could be because I am tuned and the shifts were programmed for stock output, unsure? I would shift about 500rpm before redline and then the car would display more linear acceleration. The supercharger efficiency caps out about there anyways with the tune. I'll try to get a couple runs in today given the ground is finally dry.
Mine is stock and it seems to up-change by itself around 6500rpm.
Certain try suspension in soft, it won me a tenth in quarter mile terms, the gearbox setting let me know how you go on. You might drop a 2.90s to 60 run.
#32
#33
They should fit fine, you need to check the thread about more supercharge noise and whine, I got them from ITG but you have to email/call as its not a commercial off the shelf part, all the details are in that thread.
#34
#35
#36
#38
#40
