The 10's: So Close And Yet So Far Away
Gotta be honest, I don't remember the plug codes. Might be able to find it somewhere, but VAP sells them and could tell you the specifics:
https://www.velocityap.com/product/c...-supercharged/
Appreciate the info !
DC
Hey Unhingd, sadly, I don't think there is a perfect solution for the V6. The differences in the stock v8 and v6 plugs are the electrode tip, the gap and the ground electrode core material. I wouldn't worry about the electrode core, but the V6 stock plug uses a PSPE electrode configuration which is suited for higher boost in contrast to the v8 stock and v8 heat range 8 plugs which use a standard electrode. I couldn't find a heat range 8 plug that met all of the other V6 specs (no PSPE). I suspect you could use the same heat range 8 plug as the v8 and reduce the gap to .028 - .032 to compensate for the higher boost in the v6 stage 2. I'd be dumb enough to try it, but I wouldn't feel comfortable advising others. As I'm sure you know, swapping plugs in and out for fun in these cars... isn't.
I've run the VAP crank pulley and tune with and without the colder plugs. I can't say I noticed any difference. In theory, I can now drive the car under extreme conditions longer before the ecu pulls timing.
I have a 16R lower pulley, sport cats, and vap tune with lightweight forged wheels and brand new mps4 and not matter what temperature and psi I will still spin them out the hole on the street . You do need r888r or drag radials in the rear to hook after mods. Now the track surface is always different and usually prepped so street tires might hook on the track.
iv had 2 different tunes from vap as the dealer bricked my first tune and the 2nd tune definitely had more punch from 4K to redline.
