'15 R traction issues
So I have had my R for a few months now and I am continually amazed at how little rear end traction this thing has. Rear wheels light up in 1st and 2nd with less than a quarter throttle, will easily break loose in 3rd, and it has spun up in 4th on one occassion on a cold day and cold tires. I love slinging the rear end around as much as anyone but I feel like this thing just can't put the power down. The car had 11k miles on it when I bought it and I assume they are on the OEM pirellis. There is plenty of tread left in the tires but I wonder if they had too many heat cycles and are shot. How big of a difference will the Michelins make w/ a 4-wheel alignment? Does everyone else have this issue?
Thanks!
Thanks!
Related to the R tires, you might check your air pressure. I just happened to check mine and found 27 psi, where the recommendations are 37 psi.
I have a request for advice from the forum. My 16 R AWD has 6k miles, about the time I would normally rotate and balance. However with the differing width sizes front vs rear, the only rotation seems side to side. Is that what others have decided? Also, I thought these OEM tires were directional, which would defeat that rotation, correct?
Thanks!
Doc
Thanks!
Doc
Thanks!
Doc
Thanks!
Doc
