16-17 Type R advice...
Hello,
I'm new here and have decided to look into possibly buying a 2016 or 2017 Type R.
I've searched far and wide on reliability/known issues/what I should look for and wanted to get any input from forum members with experience.
I've never owned Jag before but have read reliability has greatly improved.
Any advice would help.
Thanks.
Thanks.
The F-Type seems to be somewhat reliable. Most quality related issues seem to be addressed while the car is under warranty. However, consumer reports rates jaguar reliability as second only to the Fiat as having the worst. Jag reliability has been improving over the years, but apparently not as fast as any of the other Marques. So, beware. You have to love the car for what it is, not for what you want it to be.
I'm just looking for specific issues to be on the look out for, transmission, engine and such.
issues are usually electronics in the F-type. For example drained battery, infotainment system doing weird stuff etc.
Engine is good but not perfect, for example the coolant system has lots of plastic pipes and tubes that can cause problems as the car gets a bit older, and it is very important that the correct spec engine oil filled to the correct level has been used at all times.
The gearbox however is one of if not the best autos on the planet and completely reliable - the ZF 8HP70.
Well, first off it would be nice if you disclosed your location.
The first couple of years had some issues, and JLR continues to play catch-uo in the tech area, but at the end of the day it is the best looking production car in the world. The content has improved noticeably over the years. The performance is awesome. And people will think well of you as opposed to what they think of people who drive certain German cars. The pride and satisfaction of ownership is significant. As Dr. Unhinged said, "You have to love the car for what it is, not for what you want it to be." If its right for you, you will know it.
scm (03-07-2019)
I had an oxygen sensor replaced (which car company hasn't had the this?); a corroded grounding wire repaired, and buzzing speakers fixed via a technical service bulleting. From 16 on USA cars have a 5 year warranty that includes maintenance items (oil changes, regular service, etc.). Some forum members have had their differentials replaced. A few have had engine failure due to not monitoring oil. I'd still buy the car, if I could go back and do it over.
Yep.
Like most modern Jags the F-Type doesn't have a dipstick, instead you check the oil level via a dash readout that you have to press some buttons to access (ie there is no oil level gauge as such). Some owners are too lazy or ignorant or stupid to regularly check the oil level, next thing you know the oil level has dropped below a critical level and boom goes the engine! On the few reported cases of this happening most were after-market tuned engines and to the best of my knowledge not one of the owners ever came back with a definitive cause of the oil loss.
jaguny (03-07-2019)
Yep.
Can the oil level dash readout be programed to stay on by default?
Doubtful, but don't let this scare you. A weekly or some regular interval glance at oil level will keep you safe. It's not like you will lose a quart a day or something, to my knowledge those that had problems rarely/never checked their oil level.
How about oil temp readout?
Nup.
Unless you use Torque Pro on your phone and get the custom PIDs posted by Cambo, see here: https://www.jaguarforums.com/forum/g...p-more-213503/
You have to remember that for the last 40 or so years Jags have been marketed at owners rather than drivers, people who leave all the yucky plebian mechanical stuff to "my man James" and rarely if ever open the bonnet/hood, so pretty much zero gauges other than speedo, tacho and fuel, and that includes the F-Type. At least the F-Type has an engine coolant temperature gauge (albeit just cold to hot), my previous XFS and XFR didn't even have that!
Nup.
Coming from Porsche and BMW M this seems odd...
As others have said a few clicks on menu on steering wheel before you start engine say once per week or after engine has been run (8 minute delay)
Will show oil level and add comment of ok, over filled or under filled and advise on amount to add when needed.
If you can get into a routine of checking tyre pressure and oil level once per week/ month depending on usage you won't have any problems.
Service interval including oil change is recommended as annually or 16,000 miles whichever first
My recollection of problems reported here are:
Diff. failure (only a few)
Coolant leakage (only a few)
Speaker buzzing / rattling (common) - TSB issued that seems to have solved the problem for most.
Loss of exhaust flatulence (only a few) - Caused by TSB and subsequently solved for most with another TSB
Issues with vert top latching (very few)
Center vent failing to raise / lower (only a few)
Clutch slippage on V6 (common) - TSB issued that seems to have solved the problem.
Slow fuel filling (common) - TSB issued that seems to have solved the problem for most.
Excessive rear tire wear (mostly on 2WD versions )
Inability to remove stupid looking grin on owners (common)
jaguny (03-07-2019)
Overall, I've had far less problems with my F-Type than previously owned BMW's, Audi's and Toyota's. However, I will say that the F-Type gets driven far less than those vehicles so it's not entirely apples to apples.
At the end of the day, it's a manufactured car. Sometimes there are lemons that come off the line, but for the most part just do the normal maintenance and it will be fine. I will also add that maintenance is cheaper than owning a BMW M car.
