16' F-Type R.. lots of smoke on acceleration!
Now, I just got an F-Type R. For a steal of a deal. Brand new from the dealership. Had 49 miles (a bit high but understandable since it might have sat for a few months)
Fast forward to today, the car now has 450 miles. Two things I've noticed..
There seems to be what sounds like sand in the speakers whenever music is playing, like a hiss/static on anything with a bit of bass.
Secondly, I was with a buddy yesterday on the highway, and he told me to get on it to hear the thing.
I figured one time won't do anything, so I drop it to 2nd.. at about 30mph and romp on it. Through 2nd and halfway through third.. I look behind me, and I see a lot of smoke, like whitish/blue. I thought.. "hmm.. maybe water in the exhaust".. we pull over a short time later.. no smoke when I'm 1/2 throttle or cruising. He walks up to me, and says "dang man, must be a lot of power since the smoke"..
Now one thing to note, the smoke is only at the time I step on it, it's not sustained aka following the car and billowing out as I go.. it's only on the moment of acceleration.
Something doesn't feel right. The car feels perfectly fine. No issues besides the audio buzzing (only way to fix is to completely turn down the "sub" slider)
Once again, I get on the highway... do it again.. and what do you know.. a lot of smoke out the exhaust again and moreso in the early gears such as 1st and 2nd. I know the car is supposed to be broken in, but this doesn't seem right, have only got WOT 3-4 times and each time. Light blue in color smoke..
I WILL be taking it into the dealer, but any ideas on what it could be?
Anyone have this?
Anyone have this?
AWD :P
It's not blue per say, it's like a mix of white/blue/black really. Hard to explain, but mostly white/blue.
Another issue is this, if I go do the dealership, I basically have to romp on it in 1st or 2nd to get it to show up, yet I'm in break in stage. Remember, it's not sustained, once I'm going it doesn't follow, it turns clear/light black (like most cars)
Was the car fully warmed up when you floored it? Way you describe the smoke, it doesn't look promising. Blue smoke is caused by oil getting past scraper rings and burning up. With that much oil burning off you will notice drop in the oil level at 1-2K miles.
Now, there could be benign reasons for the smoke. They are: a. Tires. b. Water vapor c. Evap purging; b and c are likely if the car sits a lot and weren't fully warmed up.
My immediate suggestion - get engine oil changed early (as soon as possible), then monitor oil level over next 5K miles. If oil level doesn't drop - you are in the clear as far as oil burning.
I feel like the car dead hooks in 2nd with the AWD.
And hmm, any way to check the current oil level?
I should take it to the dealer right?
EDIT:
Update: I just went into the garage, and saw two drops of what looks like black fluid on my driveway. It's dried up though so it's not oil, I've only had the car about 2-3 days and it can't be older than that? Perfectly spaced out under the car. It came from the rear section under the cats.. perfectly lined up with the exhaust piping. Can oil turn to a black residue after a day or two?
Yes, there is a menu option to check oil level accessible through the steering wheel controls.
If your car is burning oil, the dealer won't be able to fix it without getting new engine or existing engine rebuilt. They won't do it until you go through break-in and oil consumption study. So there is no point bringing it up now.
I recommend you schedule oil change, wait until your car is out of break-in period then, if it burning oil, complain to the dealer.
Keep in mind, they will not easily agree to replace your engine. You have to be 100% sure it burns oil, or they WILL talk you out of it.
Also my buddy just texted me back. He was behind me when I hit it.. he said its 100% white smoke. 100%. I asked.. was there any baby blue/light blue, he said no.. 100% white. And I mean, I was going fast so maybe I wasn't fully paying attention.. but that's what he said. Although it still doesnt explain the two black liquid spots that have dried up beneath my car in the garage.
This sounds like someone (maybe at the time of assembly) spilled some oil and this is what is burning off. Give it a week to burn off.
To the OP:
I would bring it in for peace of mind. If anything does go south on you down the road, at least you will have a record of the concern that you brought up early in the cars' life.
+1. I complained about my clutch issue back in November when they claimed nothing was wrong. When I brought it in for a second complaint just recently, they weren't able to claim that I wore out the clutch prematurely since I already had the complaint on file back in November.
amcdonal86 (04-05-2016)
