17 F -type with drained battery advice/help needed.
I had an independent Jaguar shop replaced my 5yrs old battery last week after seeing “low battery messages” coming up. The “low battery” message went away after and the car was fine.
A day larder, the car threw a CEL so I plugged in a generic OBD reader to check it out. It showed a o2 senior issue, but I was not too worry about it since I know these f-types get them from time to time. Sure enough, the CEL went way over night. However, I started getting “decrease power steering”, “ “two wheels drive only, power reduced” messages the following days. I figured it was a battery related issue so I plug in my CTEK charger to the car over night. The charger shows a full charge (7 lights) each morning I checked, but those errors message would still randomly appear throughout the next few days.
After talking to a Jaguar service advisor, I decided to take the battery tender off for a couple of days, hoping that the car would “learn” that it has a new battery to solve these issues. Big mistake as yesterday I tried to start the car and only found that the battery was dead. Drained. I plug my CTEK back in over night and was able to start the car again this morning, even though the CTEK charger, over a 24hrs period, only shows 3 lights out of the 7 that it usually shows when the battery is fully charged. I even turned off the blue tooth setting as well as unplugged the phone cigarett charger
I had some times to read up about the OBDII issues posted on the forum, and suspect that my using the ODB reader may have caused the car’s electronic to stay on and drain the battery. Today, I tried unplugging the negative cable for a few minute minutes, then reattached it to reset the battery. However, the charger (after 6 hrs.) is still only showing 3 lights out of the 7, and the hazard triangle is still lid up even though the car is locked.
The next appointment I can get at the dealership is not until 1/7/22. Any advice on what I can do to reset the battery (aside from what I had already tried with disconnect the negative cable), or am I now at the mercy of the dealership tech when they get around to it in January of next year?
Just open the rear hatch, and disconnect the negative terminal for a few minutes and then reconnect it (without the charger attached). It will reboot/reset the battery. You can disconnect both cables and touch them together for a few minutes also to drain all the memory if the reboot does not/did not work. Then let the battery charge for a while until it is strong, and you should be all good.
DC
DC
Received 3,226 Likes
DC
DC
I suspect a defective new battery.
If I were the OP my first step would be to take the car to an auto parts store and get them to test the battery.
If the test comes back "no good" then go back to whoever supplied and fitted that battery and demand a new replacement.
DC
DC
No No NO! If you unbolt the black cable you have circled, and unbolt the red cable where your yellow circles is, and touch them together, you'll surely have sparks flying as both ends are still connected to the battery. I'm thinking he means to disconnect the cables at each battery post, then touch them together
The triangle stays on. Even after several battery disconnections this is still happening. I need to figure out how to make it go off.
DC
You need to figure out which circuit is still drawing current, maybe by monitoring the current draw at the battery and pulling fuses one by one. The Car Wizard did a video a while back on how he tracks down such things - he has a handy gadget.
Plum
01-28-2011 02:38 PM
