186 mph is possible
186 mph is possible
In case anybody was doubting the 186 mph limited speed
Automotive Blog Jaguar F-TYPE in Bloodhound SSC test » Automotive Blog
Dremorg (06-14-2015)
I imagine much greater than 186 is possible, since it tops out at 186 in 6th gear. And while 7th and 8th are both overdriven, you're likely to get something out of them if you removed the limiter. Likely the 186 limit is due to the tires, but i haven't researched that. The real question is how fast can you go before you run out of aero support?
At Jaguar F-Type R Coupe lap times and specs - FastestLaps.com the rwd R is "rated" at 317 km/h (196.54 mph) and 0-62 mph in 3.8 sec (0-60mph in 3.4 sec and 0-100mph in 8.0 sec).
These results are supposed to be (the best) tested performance.
rominempire
28
10-08-2020 10:39 AM
goges
10-05-2015 04:53 PM
