19" OEM S wheels fit R? Need confirmation before purchase please!
I could use some confirmation. I did a search and came up with only one thread and that thread was a bit confusing. I'm looking for a set of wheels for use during our Winters here in KS and think I found a used set of OEM's that are in good shape. They come with Continental Extreme Contact Sports DWS with 80% tread left on them. They are 2 hours away, so no way for me to test fit. No returns. Hoping to pick up this weekend if they will fit.
Can someone please confirm that a set of OEM 19" wheels off of a '16 RWD S model with the high performance braking system will fit on a '17 R with the super performance braking system? Mostly concerned about front caliper clearance.
Thank you for the help.
Received 3,226 Likes
They will fit no worries, the stock wheels on the earlier model V6S with the 380 mm front brakes were 19".
Edit - forgot to add - both the High Performance and Super Performance brakes use the exact same front brakes, the 380 mm ones, the difference is in the rear brakes 325 mm vs 375 mm. OEM 19" wheels still fit easily over the relatively puny 375 mm rear calipers.
Indy-Guy
09-06-2019 02:20 PM
Muti007
03-04-2015 07:14 AM
Diamondrmp
08-13-2013 12:19 PM
