19" Wheels?
Old 02-18-2017, 02:02 PM
abstruse1's Avatar
Default 19" Wheels?
Greetings. I just got a '17 F-type R that has 20 inch wheels, and I'm wondering if I can get 19 inch wheels to fit in terms of front brake rotor clearance. Also, are any aftermarket wheels materially lighter? Thank you.
Old 02-18-2017, 05:18 PM
Stohlen's Avatar
I believe 19" wheels do fit over the super performance brakes. But you'll want to make sure and check prior to purchase as each rim can be a little different.
Plenty of aftermarket wheels are lighter. But you get what you pay for.
Old 03-04-2017, 09:12 PM
abstruse1's Avatar
Wow. No one else knows about this issue?
Old 03-04-2017, 09:34 PM
Stohlen's Avatar
Did I not answer your questions?
Old 03-04-2017, 10:13 PM
OzXFR's Avatar
Received 3,209 Likes on 2,366 Posts
The F-Type R has the High Performance brakes as standard with the Super Performance brakes as an option (putting aside the Carbon Ceramic brakes).
Both use the exact same 380 mm front rotors and calipers.
The F-Type S comes standard with the High Performance brakes and 19" rims.
So, putting 2 and 2 together, the 19" rims from the S will fit over the front calipers on the R.
But from my experience with XF and XFR rims and brakes, this only applies to F-Type 19" rims, that is XF 19" rims will not fit over the F-Type R front brake calipers.
Old 03-04-2017, 10:28 PM
Stohlen's Avatar
Bit of an error here. The R comes standard with Super Performance brakes. The V6S comes with the High Performance brakes with Super Performance brakes as an option. However, the theory is the same as the 19" wheels should clear the brakes on the R if they clear the brakes on the V6S.
Old 03-04-2017, 10:50 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
+1. Any OEM 19" F-Type wheel WILL fit over the Super Performance Brakes.
GeDaJew (11-30-2021)
Old 03-04-2017, 11:20 PM
OzXFR's Avatar
Agreed, the R has the Super Performance brakes as standard, my bad.
That said the only difference is the rear brakes and the calipers on those are not very large (hardly any bigger than the otherwise standard 326 mm calipers, it's all in the rotor diameter), so I suspect pretty much any stock F-Type rims will fit on the rear.
Old 03-05-2017, 05:27 PM
bjg625's Avatar
I have '14 S with Performance pkg that included super perform brakes and 19" wheels.
Old 03-05-2017, 07:59 PM
drbill's Avatar
I have have a V6S with 19" wheels. I actually want 20" so I have ordered a set from HRE. They are forged wheels. The stock, OEM wheels are (usually) cast aluminum. Cast wheels are heavier and not as strong. So, to answer your questions:
1. Any 19" Jaguar F-type wheel will fit your car.
2. Most GOOD aftermarket wheels will be lighter and stronger. I went with HRE because of their choices in design and color, they are exceptionally well made (in the USA if that matters to you) and they bolt right up without spacers or different lugs. HRE are more expensive than other aftermarket options, but I think you get what you pay for.
Old 03-05-2017, 08:13 PM
Stohlen's Avatar
OEM wheels are forged more often than you'd think; however, rarely advertised as such.
Most aftermarket wheels have zero engineering involved. Looks first, strength later. Only top notch companies like HRE put real R&D into their wheels and consider things like rim fracture in the event of accidents. And since wheel fracture often prevents the rim from occupying the same space as your feet in a small-overlap crash, its something to consider. Honestly any wheel under $1000 a piece is just putting your safety at risk in the event of a crash.
Drbill: You're 100% right, you get what you pay for. Especially with wheels.
Old 03-06-2017, 06:11 PM
abstruse1's Avatar
Well, perhaps. I called up each 19' wheels thaat Jag shows on their Website. Everyone had this (or a similar) comment: "Not applicable for SVR. Not available with Jaguar carbon ceramic braking system (398mm front/380mm rear)."
But then I looked at several 20" wheels and they had the same disclaimer.
So what to think?
If it turns out that a wheel interfered by a small amount, say 1/8", I could probably grind that much off the caliper body without weakening it. Or, depending how the wheel is made, I could space it out a small amount, say <1/4".
I've thought about making a plywood mockup of the brake flange -- rotor setup, so that one could drop it in a wheel and see if there's interference. But I'm afraid that many vendors don't actually have the wheels in hand, so they couldn't try a wooden mockup.
Ultimately, I may have to spend lots of time on the phone with wheel vendors. I did email one, who replied that he couldn't guarantee fit.
Old 03-06-2017, 06:25 PM
Nati's Avatar
Do you have an SVR? Do you have carbon ceramic brakes? If the answer to either of those questions is yes, you should heed the disclaimer.
You told us you have an R, in which case even with Super Performance brakes, the 19" OEM wheels should all fit.
Old 03-06-2017, 09:11 PM
abstruse1's Avatar
I do not have an SVR. I do have an R with "carbon ceramic matrix braking system."
Nati, I was confused regarding these two terms. I'm looking at my window sticker that says "carbon ceramic matrix braking system" under the Optional Equipment column. It also says "Super Performance Braking System" under the Standard Equipment column. I would interpret this to mean that the car has the ceramic brakes, the Options column having precedence over the Optional Equipment column. My mistake.
So the question remains (in my mind, anyway) as to aftermarket wheels fitting w/o modification, or Jag wheels with some acceptable degree of caliper modification.
Old 03-07-2017, 10:33 PM
Nati's Avatar
It sounds like you indeed have the carbon brake package. Your calipers should be yellow and say "carbon ceramic" on them. Incidentally, that was $12,000 added to the price of your R :-)
No OEM 19" wheels will fit over the fronts, and I think it would be nigh impossible to find aftermarket 19s that would as well. The only OE 20s that will fit are the Storms (which you have) and the Maelstroms that come standard on the SVR. And please don't modify $12,000 brakes :-)
Old 03-08-2017, 05:04 AM
Unhingd's Avatar
+1.
Old 03-08-2017, 09:41 AM
abstruse1's Avatar
Well, if I were to stick to the 20" wheels, are there aftermarket wheels that are significantly lighter?
And as to tires, I read somewhere that the new PSS tires may ride better, may be quieter, and offer at least as good traction as the P-Zeros. Any ideas about this? Or other tire recommendations?
Old 03-08-2017, 09:51 AM
Unhingd's Avatar
The PSSs might be just a bit louder, but ride much better and outperform the P-Zeros by a mile. The PS4s (that are replacing the PSSs) are even better than the PSSs.
Old 03-08-2017, 02:16 PM
DPelletier's Avatar
Why would you want to put 19" wheels on an R with Carbon brakes anyhow? .....just curious.
Dave
Old 03-08-2017, 02:37 PM
abstruse1's Avatar
Better ride quality and lower road noise.
