19" wheels to 20" wheels, can I ?
Tornado 20"
Actually my wheels were just powder coated gloss black and bringing my car into the shop to have them out on today!
Went from the 19" base model to the 20"tornados they came in silver since I got a great price on them and just had them powder coated to the gloss black
And had them order the standard size that should be on the 20" for the ftype
Not to hijack the thread, but along a similar line as changing wheels...
I'm curious if it's possible to change from the regular steel brakes to the carbon ceramic brakes?
I'm thinking of taking mine to the track, and if I get hooked, that's the one option that I wish it had come with that I would want.
Not certain if I'd do it because I know the cost would be outrageous, but I'm just wondering if it's possible.
Anything is possible with enough money. In addition to the calipers and rotors you will probably have to change out the master cylinders and maybe even the brake control module.
Its likely they engineered the calipers to work with the same master cylinder .. Versus having 3/4? different master cylinders - one for each level of brakes. I'm betting its just a straight rotor/caliper/mounting bracket swap.
Easy enough to check out in the parts book, but given the different sizes of the caliper pistons, it's almost certain that the master cylinders have to be changed out. That had to be done on my MINI when I upgraded to their high performance brakes.
scooternva
19
10-27-2015 02:14 PM
lickahotskillet
09-11-2015 07:54 PM
