200 Cell Cat installation guide?
supersportmtl (10-17-2020)
You need torque adapter with at least a 2 inch span and a wobble extension so that you clear the OEM cat while maintaining full seated contact with the nut because it's pretty much "seized" on with the heat cycles and rust. I did not do the job myself because I got go the point of not having the right tools to do the job without risking stripping the nut. With the right tools it can be done!
https://shop.snapon.com/product/Stan...r-Set/208FRDHM
