2002 Jaguar XJ8 master window switch
I took the drivers interior door trim panel out in order to change the drivers outside door latch. I disconnected the wires to the tweeter, speaker, master window switch, and courtesy light. I got the the latch changed. I put the interior door trim panel back on, hooking up all the wires. Now the master window switch will only operate the drivers window using the switch that is supposed to operate the passenger side rear window. It won't operate any other windows. All the other switches will operate the other windows. I have disconnected the master switch and reconnected several times. I don't see how the switch for the passenger rear window in the master switch can operate the drivers window and the drivers window only. It will not operate any other windows. I wonder if anyone has had this problem or can understand what is going on.
ChristianC
12-31-2019 10:20 AM
mark campbell
10-22-2013 06:53 AM
