2014 F-type p0169 Incorrect Fuel Composition Code
Anybody else ever run into a p0169 Incorrect Fuel Composition error code? I was driving into work this morning and I got a "Special Modes Unavailable" and the car felt like it wasn't getting power to the back tires. It was running a little rough when I pulled over but after I shutdown and started back up she smoothed right out. I did have it happen 1 more time driving into work and when I ran the code, I got a p0169 Incorrect Fuel Composition. Anybody else experience this issue? 2014 base V6 with VAP Tune and Crank shaft fully upgrade.
Thanks!
Thanks!
I'd start with VAP. The OBD Guide mentions the code, and lists ECU Fault as one explanation. Not much info - search for the code.
https://www.dropbox.com/s/1ek33ux7tf...guide.pdf?dl=0
evilftypedw (02-19-2018)
evilftypedw (02-20-2018)
Thanks!
Thanks!
Union 76, Aloha Petroleum, Amoco, ARCO, Beacon, BP, Break Time, Cenex, Chevron, CITGO, Conoco, Co-op, Costco, CountryMark, Diamond Shamrock, Entec, Esso, Express, Exxon, Holiday, Kwik Star Stores, Kwik Trip, Mahalo, MFA, Mobil, Ohana Fuels, Petro-Canada, Phillips 66, PUMA, QT, Quik Trip, Road Ranger, Shamrock, Shell / Shell V-Power, Sinclair Standard, SuperAmerica, SuperFuels, Tempo, Texaco, Tri-Par, and Valero
With some circular reasoning...I suppose its possible that a P0169 indicates a fault in the sensor that causes a P0169... what sensors does the car have - fuel composition sensor or water in fuel sensor?
Alternatively, for testing purposes, it probably wouldn't hurt to top off with some fuel from somewhere else and see if the error goes away.
mshedden (02-20-2018)
So this took an interesting turn... the dealer said it's a software update to resolve the issue. They backed out the VAP tune (with my tuner box) and then updated the ECU. Supposedly it's fixed, but I won't know until I get to drive it bit. Thanks everyone for their input. Hopefully this is it and the car is happy again.
Already talked to Chris late today and he said to try his previous tune first. If it doesn't allow me to install, then send him the new map and he'll get me a new tune. They are great to work with!
evilftypedw
02-21-2018 03:45 PM
Mr. Dusinovic
11-12-2014 03:50 PM
pomosv
11-23-2012 12:01 AM
