2014 F Type Purchase Concerns
Hello,
I currently own a 2012 XF and I have been wanting to upgrade to the F Type V6 S. I found a clean example that peaked my interest, but while checking the Carfax I found a few redflags:
02/01/2016 24,396
Maintenance inspection completed
Brakes checked
PCM reprogrammed ----------- Is this just a normal PCM reprogram or should I worry?
Tire condition and pressure checked
Wiper(s) replaced
11/18/2016 39,072
Coolant bypass pipe/hose replaced --------- Is this a common issue?
Cooling system checked
Rear brake pads replaced
Tire(s) replaced
Two tires balanced
Two tires mounted
The car is late 2013 build, are there big ticket items I should worry about since this is a early production car?
Your input is appreciated!
02/01/2016 24,396
Brakes checked
Wiper(s) replaced
11/18/2016 39,072
Tire(s) replaced
Two tires balanced
Two tires mounted
I agree that it was likely just a routine ECU update, there's bound to have been at least one since release. I would also agree that the coolant hose would be more concerning, however if all they replaced was a hose, it was likely due to a small leak. If the car had overheated, I imagine you'd be seeing a water pump replacement in the history as well.
Looking at my service history (early 2013 car):
The K309B TSB (O2 sensor calibration) lists 'configure existing PCM using IDS/SDD'
If you have detailed service info, check for:
K192 folding top enhancement
K243 climate control center vent (if it doesn't go up/down smoothly on its own)
J047 seatbelt tension wiring ('swapped wires in connector')
I've also replaced 2 O2 sensors (common), and purge control valve.
Jaaaggg (09-16-2017)
