2014 V8S Tune
I'm really considering getting a tune for the car, however I don't have any "warm and fuzzies" regarding who and how. A few vendors offer remote tuning via an android device and cable, but I haven't found any substantial informative positive or negative reviews. There is a Eurocharged dealer in Maryland, ISP Racing, but I don't know if anyone has had the F Type model (much less any Jag model) tuned there. Viezo is supposedly making their V-Switch compatible sometime in the near future, which would store the factory tune along with two other custom tunes, but I haven't been able to find any evidence of the quality of their tunes by research either.
I know some members do have tunes for their cars, can someone share?
Thanks,
Charlie
Thanks,
Charlie
What are you trying to achieve with your tune?
If it is to reduce fuel economy, undermine long-term reliability for marginal boost in near redline performance, then 'remote' app tune is quite appropriate.
If you want to gain noticeable power gain, then there is no way around doing some wrenching.
While I agree with the sentiment, there is zero hardware difference between the 488/495/510ps V8S and the 550ps V8R so there is DEFINITELY a way to boost the power the difference between the two (which is arguably around 40hp) without negatively affecting....anything. Now, whether or not anyone has come up with a well thought out, comprehensive software upgrade to do that or not is a different question....
Other than exhaust, I'm not aware of any other physical differences for the 575hp P7 and SVR either.
SOMEONE did a modified R download into a V8S as well....
Cheers,
Dave
SinF (03-29-2016)
I have a remote tune, as do many others and picked up 4mph on the 1/4 and went from 11.70 to 11.44. I have countless 1/4 mile passes and several 1/2 passes.
Anyway I think some performance gains could safely be achieved by a remap, like increased throttle response and hp. I thought I did read here somewhere about the R map being flashed to the S.
I have used handheld devices for a couple of previous vehicles, 07 Mustang GT (SCT tuned by Chris Rose) LTs and CAI, 07 Shelby GT500 (SCT tuned by Jon Lund) CAI, TB, and pulley, and a 13 Camaro ZL1 (Diablosport tuned by Lew), CAI and TB - so I have turned a wrench or two. The driving characteristics for all those changed noticeably for the better along with the convenience of flashing to the factory tune and reading of any codes. It just seems that information regarding tuning of the F Type is for the most part non existent.
I guess time will tell.......
Thanks for the replies,
C
That being said, there are many tunes available, with questionable results. APVelocity, which I believe to be the most reputable and active tuner currently on this forum, just tuned an R with some impressive gains. Hopefully they will post those shortly.
In addition Eurocharged Performance and Eurotoys seem to make decent products as well, though I've never talked to them much about it. I've heard good things. Hennessy makes a tune also, probably the biggest company, but I've seen horror stories.
Thanks,
Charlie
Thanks,
Charlie
Check out John Behe at ASM Performance in Hanover, Maryland:asmperformance. He has a Dynapack and both Jaronstoys and I are extremely pleased with the tuning he has done for us.
Proper tuning just can't be done without the car sitting on a load simulating dyno. I would suggest ignoring the mail order tunes.Though some of them might be quite effective, there's no way of assuring that your specific vehicle isn't exceeding safe parameters without data logging while under load. Data logging while driving would require speeds of up to 130mph in 4th gear which is not particularly viable.
Stohlen (03-29-2016)
Anything else is ether snake oil or gambling that you won't suffer catastrophic failure by applying different car's tune to yours. Proper tuning (which could not be done without putting your car on expensive dyno machine) will minimize the risks of catastrophic failure. This cannot be done remotely.
There are some risk with any tuning, but they could be managed if done properly. Unless it is "remote tuning via an android device and cable".
Maybe you are not mechanically inclined and don't know the difference between dyno runs and android device and a cable. Let me try analogy. Say you have an investment stock portfolio. I could 'tune' it with robo adviser or I could have Warren Buffett pick your stocks. Which one do you think will work out better for you?
I have hard time believing that Jag would intentionally take a car that is capable of higher performance and down-tune it. You do realize that they have to compete with other brands, like Porsche, and if they could make base perform at R levels, they absolutely would, because that would move more cars off the lot and more than offset loss of margins from occasional R sale. Basic economics dictate that there are hardware differences.
To get more power you need to get in more air and more fuel and move out more exhaust. This means you have to improve intake, exhaust, or fuel delivery to see gains. You could also see gains by reducing rotational mass, but this is generally cost-prohibitive due to expensive materials (titanium) or seriously undermines longevity (hollowed/drilled parts).
It is actually very common to have the same basic engine design produce vastly different outputs with what may appear to layman as minor differences (bolts, gaskets, pistons, valves, flywheel).
One example of this that I am intimately familiar with is Mercedes M113 V8 engine. They put them into E class producing 280hp and into SLR McLaren producing 600hps. I don't think I have to explain that you couldn't possibly get 600hps out of E-class M113 even if they share a great deal of parts.
This is... absolutely, positively, 100% exactly what Jaguar did... Basic economics tells you that if you sell something, and then a year or two later sell a new product that makes that old product inferior, people are going to trade up... which means you sell another car. Economics also teaches us that engineering one, more expensive (per raw material/labor) set of hardware costs less than engineering 3 different sets.
You're missing the point that the V8S, R, AWD R, P7, and SVR all use the same 5.0L block with the same supercharger, same pistons, same accessories, etc. and are only tuned differently to provide additional model designations. Its not like the engines in these vehicles are different displacements, or built for superchargers vs. naturally aspirated variants like your example. Do the research like we have.
There must be mechanical differences between each new iteration. While they are 99.9% the same car, that 0.1% makes all the difference (and takes a lot of engineering).
I could, for example, get your Impreza 4 cylinder boxer engine and have it produce 310 HP (WRX). I might even figure out how to do this with an app. It will work for about 10 seconds, before it blows up. Both use a lot of similar parts, but they are not identical engines.
You are sadly mistaken if you think Jag produces R-types, then de-tunes some of them to sell as S, then de-tunes more of them to sell as base model. You are also very mistaken if you think that some 'app and a cable' can turn any F-type car into R. I refuse to believe this is the case, as it defies any logic or reason.
Philly Single (03-30-2016)
They didn't "detune" an R, they offered it as a 495/488 (and in reality a 510ps) version, then the following year they bumped the tune and reissued it as a 550 to entice new buyers, then they changed the exhaust, changed the tune and re-issued the 575hp version. this is ZERO difference in the block, heads, manifolds, superchargers, pistons, rods, rings, etc. etc.
What, you think the 495 was going to self destruct at 550 so they designed a completely new engine for 2015....seriously? you obviously have no clue.
Dave
Dave
