2015 F Type
Received 3,209 Likes
In relation to my previous post i was given some wrong info. it's not below the outlet of the water pump ,it's on the outlet it self, there is a brass fitting on the outlet with a small tube to line attachment. It's like a clip inside the brass fitting and a tube which goes inside the clip with a hose attachment. It's on the outlet of the water pump.(the gooseneck) sorry for the bad info. thanks Gary
I could have added the next page or two showing the hot climate parts callout as well but I didn't think it would be of any use to the OP.
Looking at the two different pics and part listings in my copy the only difference I can see is the hot climate version has an extra radiator (called an auxiliary radiator) down low and in front of the main radiator, and at right angles to it, so that is how you can tell which version of the cooling system your car has.
If you want I can post up those extra pages, or you can get the entire Workshop Manual from my Dropbox here: https://www.dropbox.com/s/d52ciochjn...anual.pdf?dl=0
Carbuff2 (03-20-2019)
Jaguar Forums Editor
Jaguar Press release
11-26-2013 01:43 PM
12-22-2012 06:08 AM
