2015 F-Type R, no start, need advice
#61
I am/was having this problem tonight. Took it out to dinner and went back after to start the car and had the same sound/no starting. Key is recognized inside and outside of vehicle, engine start/stop button would provide power to the interior and exterior lights. I finally went to the trusty Jaguar Remote app and tried the remote start feature and the car started up. Not sure how it was able to start with the remote app, but was able to get the car on and drive it home to get it back on the CTEK tender. I am thinking something either in the engine start/engine stop button isn't functioning or some other gremlin at this point. Any other thoughts??
#62
#63
Going to see if I can get it to start normally after sitting on a CTEK all night, I'll test after the Grand Prix this morning and provide updates. @DJS I'm seeing the message to press brake pedal and when I press it the screen in the center dash acknowledges me pressing it. I am thinking culprit is either the brake pedal sensor or engine start button.
#64
#65
- car has been in hibernation. Too cold to work on it, salt and snow, don't have enough space to work on the car inside. But weather nice this weekend so *finally* pushed it out and got it up on stands.
- ground from starter body to chassis and main power supply cable from battery both look good/clean
- voltage measured from battery supply at solenoid post to ground (via ground wire) shows 12.6v
- here is the kicker, had my daughter try to start the car while I monitor voltage from solenoid out post to motor and same ground, I see maybe a volt or two for a short duration, and I *think* I hear the motor whirring (but bendix not engaging), so estimate it is the solenoid
- pulled the starter, tested it (battery hooked directly to solenoid in and neg to starter body, bridge a screwdriver to solenoid trigger), motor turns and bendix engages. Wtf.
Next step is to check the flywheel, maybe turn it a bit to make sure it's not some weird alignment issue, bolt the starter back in, make sure the trigger wire harness is nice and snug, connect up the power and ground, and see if it fires or does the same thing.
If same thing, then it must be upstream from the trigger harness. The mystery continues - but it doesn't seem to be the starter. Maybe when I bolt it back in it will just work?
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Lmk what happens after you trickle charge it.
erontica (03-22-2022)
#66
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Interesting, wish I had remote start on my 2015. Your situation might point to a brake switch as that would be bypassed by the remote start. Mine does the same, shows the press brake message which goes away after I actually press the brake so I de-prioritized checking the brake switch after that, but maybe there is still something to it? My current status:
not holding my breath!
#67
Borbor (03-23-2022)
#68
In another life I was the network ADM for a small enterprise. What I commonly found while troubleshooting PCs was that unplugging and plugging things back in on the motherboard often made the problem go away. Even in the house, if the electronic ignition water heater was flashing an error code, just pulling the plug, counting to 30 and plugging back in cured its ails. Pulling and refitting the memory boards in PCs was another. It's totally possible that removing and reattaching all the parts that you did made a better connection than what was there. Hope the gremlins stay away!
#69
Sounds like you're getting to the bottom of it. You may want to add one more step before bolting the starter back in. Connect the wiring but leave the starter off the housing. Ground the starter body and repeat the daughter start test while observing the business end of the starter. This will remove the rest of the car from the equation. I'm still thinking bendix. Usually if it's a flywheel alignment problem the starter will make the devil's own noise as the bendix gear grinds against the flywheel trying to engage. Maybe not extending far enough?? Good Luck!
#70
![Embarrassment](https://www.jaguarforums.com/forum/images/smilies/redface.gif)
#71
#72
Also regarding the bendix not meshing with the flywheel and making noise, that makes sense. There was another forum post I dug up from a while ago where the guy had exactly the same problem. Unbolted the starter, tested, all worked fine, so he moved the flywheel slightly with a screwdriver, bolted it back up and it started. But thinking about your comments, if that were the actual cause it would definitely make all sorts of racket. My theory for him is solenoid was stuck a bit and was shaken loose, or maybe the harness on the back of the solenoid was loose. Not sure but hoping I have the same luck as that guy when I volt everything up again - so far I haven't been feeling the luck though!
Carbuff2 (03-27-2022)
#73
My dad had a 70 Thunderbird that would do that. If the engine stopped in a certain place, the bendix wouldn't engage, but it would make quite a racket (similar to an air impact wrench with a little more metal to metal tone). He would make me get out and turn the engine by hand by pulling on the fan belt. 10 to 20 degrees and it would engage. It was a 429 so not fun to turn by hand. We solved it by slightly enlarging the mounting bolt holes and moving the starter a little farther away from the flywheel. Sounded like a Plymouth with the starter engaged, but always worked after that. That doesn't sound like your problem as the sound of the bendix banging into the flywheel is something that you didn't describe and is hard to miss. If everything works with the starter connected electrically but not installed, I would make sure to bias the starter away from the flywheel within the slop of the mounting holes just to eliminate that as a possibility.
#74
The flywheel interference problem is often accompanied by a "klunk" when the bendix hits the flywheel.
A bit of grit in the wrong place may allow the starter & Bendix to spin but "seize" the extension toward the flywheel.
A similar problem on a non-Jaguar application was resolved with WD-40 followed by a lightweight lubricant once the part moved freely.
Alternatively, you may replace the Bendix or the entire starter.
Please post your solution.
Bill
Bill
#75
Bill
Bill
Latest news, I pulled the starter off, tested it, worked fine. Then while pushing my car back into the garage I shut the rear hatch, with the battery diaconnected. Tried a bunch of stuff, including jumping from the front terminals, to no avail. Had a hunch me having the starter out of the car disconnected the front jumper terminal, but at that point I had "had it". Just no time and weather not cooperating - so had it brought to a local shop to look at it. They specialize in Jaguars but I guess not these so much - they are stumped after running some diagnostics, resetting the computers, etc. Last ditch effort - there was a fault from the battery management sensor in the trunk that tracks battery temperature - diagnostics said it was reading -40C. The thinking is that fault is causing the no-start - I feel that we are reaching though, a battery warning light maybe, but I'm doubting it would stop the car from starting. The message from my mechanic - if this doesn't work he's done with it and I'll need to have it moved to my local Jaguar dealer. Oh goody. Must say I've never had a car give me fits like this after driving it ohh.... maybe 200 miles?
#76
Here's a theory that fits: there may be some shorted turns in the Bendix solenoid. It would still work but would be very weak, barely able to push the spur gear into the flywheel. This might explain it working only sometimes. A properly working solenoid will make a very audible "clack" when driving the gear out. Not much to do about it other than just replace it. I don't have an F-Type so don't know if the solenoid is separate or part of your starter. Either way, try replacing it.
#77
I agree with KB58. I had an 81 Corvette that had a similar starter issue.. sometimes worked, sometimes not. If I reached in and whacked it with a lightweight hammer it would go. Replacing the starter (with solenoid) ended the problem. Did you say you replaced the starter? It may just be after 7 years (yours is a 2015?) that it's done.
Please keep posting your updates... this could happen to any one of us.
#79
Valerie Stabenow (04-16-2022)
#80
It could happen to any one of us. The other thing I learned from car ownership is "new" doesn't necessarily the part works. DOA has happened too many times. It took me 3 alternators on my E before I got one that worked. You have more than sufficient knowledge so nobody can BS you. Hang in there!
