2016 F-Type instrument cluster removal
Good luck. Hope it helps.
DC
F-Type Instrument Cluster
AaronLin (01-28-2021)
Best of luck
Mark
glschmidt, this was quite the undertaking, I downloaded several diagrams of the cluster and was able to remove all of the screws without removing the airflow duct. I had to make a specific adjustment to the torx bit by cutting it down both top and bottom to remove the inner most screws (2) I believe. I glued the torx into a narrow flat HVAC ratchet to remove these nasty buggers. I can look for the diagrams that I used and possibly find the modified torx bit if it will help you.
Best of luck
Mark
Best of luck
Mark
TAEUCK Goo
11-30-2020 07:28 AM
